Connexion du Capteur à l'IPX
if (d < 20 || d > 150) {
return "";
}else{
return d + " cm";
<style>
.content {
position: absolute;
bottom: 0;
left: 0;
height: 100%;
width: 100%;
background-color: #333;
overflow: hidden;
.circle {
width: 5px;
height: 5px;
position: absolute;
left: 50%;
margin-left: -2px;
top: 50%;
margin-top: -2.0px;
border-radius: 50%;
border: 2px solid #3C14;
animation: radar 5s infinite;
transition: all ease-in;
@keyframes radar {
1% {
width: 5px;
height: 5px;
margin-left: 0;
margin-top: 0px;
border: 2px solid #3AA65E;
opcity:0.9
100% {
width: 300px;
height: 300px;
margin-left: -150px;
margin-top: -150px;
border: 12px solid #055E23;
opacity:0.0;
</style>
</div>
</div>
Voici notre widget :
Widget avancé
Le câblage
En résumé,
Voici le schéma de câblage :
Le dashboard
return "";
}else{
return d + " cm";
<style>
.content {
position: absolute;
bottom: 0;
left: 0;
height: 100%;
width: 100%;
overflow: hidden;
.circle {
width: 5px;
height: 5px;
position: absolute;
left: 50%;
margin-left: -2px;
top: 50%;
margin-top: -2.0px;
border-radius: 50%;
animation: radar 1s infinite;
@keyframes radar {
1% {
width: 5px;
height: 5px;
margin-left: 0;
margin-top: 0px;
opcity:0.9
100% {
width: 300px;
height: 300px;
margin-top: -150px;
opacity:0.0;
</style>
</div>
</div>
`;Voici le Widget Complet :
Les Scènes
